| • | Orion NPM |
| • | Orion IPAM |
| • | Orion NCM |
| View All | |
Your changes will require approval by an administrator before they are published.
The article has been updated successfully but requires approval before it is published.Flow packets will be ignored by Orion NTA if they do not include the following fields in your Flow template:
| Field Type | Field Type Number | Description |
IN_BYTES |
1 |
Ingress bytes counter |
IN_PKTS |
2 |
Ingress packets counter |
PROTOCOL |
4 |
Layer 4 protocol |
L4_SRC_PORT |
7 |
Source TCP/UDP port |
IPV4_SRC_ADDR |
8 |
Source IP address |
INPUT_SNMP |
10 |
SNMP ingress interface index |
L4_DST_PORT |
11 |
Destination TCP/UDP port |
IPV4_DST_ADDR |
12 |
Destination IP address |
OUTPUT_SNMP |
14 |
SNMP egress interface index |
Notes:
INPUT_SNMP and OUTPUT_SNMP) should be provided to view accurate statistics for both ingress and egress flows.SRC_TOS field corresponding to the service type of ingress traffic on an interface (field type number 5) is required to view Type of Service information for your traffic through a Flow source. The templates used by Cisco 4500 series switches and Adaptive Security Appliances (ASA) does not provide information in this field.TCP_FLAGS field (field type number 6) corresponding to a count of all TCP flags seen in the related Flow.
This article applies to:
NetFlow Traffic Analyzer 3.0 and later
Last Updated
18th of June, 2010
Thank you for rating this answer.
Enterprise-Class Network Management
Entry-Level Monitoring
Enterprise-Class Storage Management
Tools for Engineers
Prices displayed do not reflect international pricing unless otherwise stated. Please see our international price list for current pricing specific to your location.
All prices are subject to change without notice.
© 2003-2010 SolarWinds. All Rights Reserved.
