Your changes will require approval by an administrator before they are published.
The article has been updated successfully but requires approval before it is published.ASA NetFlow export is dependent on the version of ASA software running. ASA version 8.2 software supports NetFlow export across all ASA models, but some models may function on a lower software level. The following fields must be included in the ASA configuration to export flow data to the Orion NetFlow Traffic Analyzer module.
Notes:
flow-export enable command also included.For a detailed explainition of ASA NetFlow see the Understanding Cisco ASA Netflow technical reference.
The following commands must be included in your global service policy for ASA NetFlow export to function.
(config)# flow-export destination <interface name> <Orion server IP address> 2055(config)#flow-export template timeout-rate <#_minutes>(config)# flow-export delay flow-create <#_seconds>(config)# logging flow-export-syslogs disable(config)# access-list netflow-export extended permit ip any anynetflow-export to specify the traffic of interest. The provided syntax includes all traffic.(config)# class-map netflow-export-classnetflow-export-class.(config-cmap)# match access-list netflow-exportnetflow-export access list to the defined netflow-export-class class.policy-map <existing global policy name> policy-map global-policy(config-pmap)# class netflow-export-classnetflow-export-class class to the defined netflow-policy policy.
(config-pmap-c)# flow-export event-type all destination <Orion server IP address>(config)#flow-export enable This article applies to:
Orion NetFlow Traffic Analyzer 3.5 SP2 and higher
Last Updated
13th of May, 2011
Thank you for rating this answer.
SolarWinds makes award-winning storage management, application management, server management, and network management software trusted by more than one million engineers to manage IT environments ranging from tens to thousands of devices.
Discover our network monitoring, configuration management, network mapping, and free network tools today!
Enterprise-Class Network Management
Enterprise-Class Application & Server Management
Enterprise-Class Virtualization Management
Enterprise-Class Storage Management
Tools for Engineers
Easily monitoring bandwidth usage on a troublesome interface!
Record and test web transactions with the touch of a button!
Quickly discovers all of your virtual machines, then estimates what it would cost to move them to the cloud.
Prices displayed do not reflect international pricing unless otherwise stated. Please see our international price list for current pricing specific to your location.
All prices are subject to change without notice.
© 2003-2012 SolarWinds. All Rights Reserved.
