Welcome! Use the login menu to access:
Customer Portal
SolarWinds customers can download purchased software, renew maintenance, & more in our updated Customer Portal!
After logging in, community members can rate & review SolarWinds software & participate in forums on thwack.com.
Partner Portal
SolarWinds channel partners will find all the resources they need in the Partner Portal, including exclusive partner tools.
| More
SolarWinds Knowledge Base
Apresia Device Sends Constant and Erroneous Realtime Change Notifications
NCM software is receiving continual realtime change notifications; or receives a notification from the Apresia device each time the config is downloaded or a script is executed that does not change the device's configuration.
This issue occurs due to a command in the Apresia device template that puts the device into config mode each time you connect to the device and sends a ‘terminal length 0’ command to turn off the "More" prompt.
Unlike Cisco devices, which configure terminal display per config session, Apresia sets display properties persistently. So, since this operation needs to be done only once, and then the setting persists, you can safely remove the 'terminal length 0' command from the device template; and doing so resolves the issue with RTNs.
To remove the command from the template:
  1. Open Apresia device template located in  NCMInstallDir\DeviceTypes\Apresia 3424GT and 13200-
  2. Replace existing line with reset command by the following one:
    <Command Name="RESET" Value="">
  3. Save your changes.
On the Apresia device, to set appropriately set the terminal length, login and issue these commands:
  > enable
  # conf t
  (config)# terminal length 0
  (config)# end
Related Articles
No related articles were found.
No attachments were found.
Visitor Comments
No visitor comments posted. Post a comment
Post Comment for "Apresia Device Sends Constant and Erroneous Realtime Change Notifications"
If this article does not provide the solution you need, please consider visiting our community forums on thwack or contacting SolarWinds Support. Please use the following form to provide comments that help us improve this KB article. Fields marked with an asterisk are required.
* Email:
* Comment:
* Enter the code below:
Article Details
Last Updated
27th of June, 2012
Would you like to...
Print this page  Print this page
Email this page  Email this page
Post a comment  Post a comment
 Subscribe me
Subscribe me  Add to favorites
Remove Highlighting Remove Highlighting
Edit this Article
Quick Edit
Export to PDF
User Opinions
No users have voted.
How would you rate this answer?
Thank you for rating this answer.
