Welcome! Use the login menu to access:
Customer Portal
SolarWinds customers can download purchased software, renew maintenance, & more in our updated Customer Portal!
Community
After logging in, community members can rate & review SolarWinds software & participate in forums on thwack.com.
Partner Portal
SolarWinds channel partners will find all the resources they need in the Partner Portal, including exclusive partner tools.
| More
SolarWinds Knowledge Base
Resizing a LEM Virtual Appliance v5.4 or below
The default size of the LEM virtual appliance is 250 GB. Starting with version 5.4, you can increase and decrease the capacity of your LEM virtual appliance using two distinct methods. The following sections describe how to do each.
Increasing the LEM Virtual Appliance
You can increase the capacity of your LEM virtual appliance by increasing the hard disk in your vSphere or Hyper-V client. If you want to increase the size of your virtual appliance, consider the following notes:
  • Due to licensing restrictions in versions up to 5.6, you can only increase the disk size up to a maximum of 1 TB.
  • After you increase the size of your virtual disk, you cannot decrease it using the same methods.
  • You cannot increase the size of your virtual appliance if you have snapshots for the VM.
Decreasing the LEM Virtual Appliance
If you need to decrease the capacity of the virtual appliance, create a smaller (secondary) hard disk for the virtual appliance in your vSphere or Hyper-V client, and then start the virtual appliance to automatically clone the existing disk to the secondary hard disk.
Note: The new disk must be large enough to accommodate all of the data on the existing disk, but it does not have to have the same maximum capacity.
To clone a disk in vSphere:
  1. Open vSphere.
  2. In the left pane, select the LEM appliance.
  3. In the Inventory menu, click Virtual Machine > Power > Shut Down Guest.
  4. Add the new disk:
    1. In the Inventory menu, click Virtual Machine > Edit Settings.
    2. Click Add.
    3. In the center pane, select Hard Disk, and then click Next.
    4. Select Create a new virtual disk, and then click Next.
    5. Enter the settings for a new hard disk that is large enough to accommodate all of the data on the existing disk.
    6. Click Next.
    7. In the Virtual Device Node menu, select SCSI (0:2), and then click Next.
    8. Click Finish.
    9. Click OK.
  5. Back on the vSphere Client window, click Inventory > Virtual Machine > Power > Power On. The appliance starts up, clones the primary disk to the new disk, and then shuts down. This takes between 15 minutes and several hours, depending on the size of the disk.
  6. Replace the old disk with the new one:
    2. In the left pane, select the old hard disk.
    3. Click Remove.
    4. Select the new hard disk.
    5. In the right pane, select SCSI (0:0) in the Virtual Device Node menu.
    6. Click OK.
  7. Power on the LEM appliance.
To clone a disk in Hyper-V:
  1. Open Hyper-V Manager.
  3. In the Actions pane (right), click Shut Down.
    1. In the Actions pane, click Settings.
    2. In the left pane under Hardware, click IDE Controller 0.
    3. In the right pane, select Hard Drive, and then click Add.
    4. Under Virtual hard disk (.vhd) file in the Media section, click New.
    5. On the New Virtual Hard Disk Wizard window, select Fixed size and then click Next.
    6. Specify a name and location for the new disk, and then click Next.
    7. Specify a size for the new blank disk that is large enough to accommodate all of the data on the existing disk, and then click Next.
    8. Click Finish.
    9. In the left pane under IDE Controller 0, select the new hard disk.
    10. In the right pane, select 1 in the Location menu.
    11. Click OK.
  5. Back on the Hyper-V Manager window, click Start in the Actions pane. The appliance starts up, clones the primary disk to the new disk, and then shuts down. This takes between 15 minutes and several hours, depending on the size of the disk.
    2. In the left pane under IDE Controller 0, select the old hard disk.
    3. In the right pane, click Remove.
    4. In the left pane under IDE Controller 0, select the new hard disk.
    5. In the right pane, select 0 in the Location menu.
    6. Click OK.
Related Articles
No related articles were found.
No attachments were found.
Visitor Comments
No visitor comments posted. Post a comment
Post Comment for "Resizing a LEM Virtual Appliance v5.4 or below"
If this article does not provide the solution you need, please consider visiting our community forums on thwack or contacting SolarWinds Support. Please use the following form to provide comments that help us improve this KB article. Fields marked with an asterisk are required.
   Name:
* Email:
* Comment:
* Enter the code below:
Article Details
Last Updated
2nd of May, 2013
Would you like to...
Print this page  Print this page
Email this page  Email this page
Post a comment  Post a comment
 Subscribe me
Subscribe me  Add to favorites
Remove Highlighting Remove Highlighting
Edit this Article
Quick Edit
Export to PDF
User Opinions
No users have voted.
How would you rate this answer?
Thank you for rating this answer.
Continue
