Your changes will require approval by an administrator before they are published.
The article has been updated successfully but requires approval before it is published.How do I remove the debug information from my web console?
When you install your SolarWinds Beta, SolarWinds launches some diagnostic tools, by default, as seen in the screenshot below. These diagnostic tools are very helpful when running performance tests and when troubleshooting certain problems. If you would prefer not to see these tools, you can remove them, as indicated in the following procedure.
To remove SolarWinds diagnostic tools from Beta web console views:
Note: Running the SolarWinds Configuration Wizard will overwrite the edits made in this procedure. If you run the SolarWinds Configuration Wizard after completing this procedure, you must complete the edit provided in this procedure again to remove the debug information from your web console.
SolarWinds folder.C:\Inetpub\SolarWinds.web.config. <add key="HubbleActive" value="True"> </add>True to False.web.config.This article applies to Beta versions of all SolarWinds products using Orion Platform 2012.1 and higher.
On the server you installed NPM on, go to the webroot and find the SolarWinds folder (by default this is C:\Inetpub\SolarWinds) and open the web.config file. Around line 78, you should see something like this:
Last Updated
1st of March, 2012
Thank you for rating this answer.
SolarWinds makes award-winning storage management, application management, server management, and network management software trusted by more than one million engineers to manage IT environments ranging from tens to thousands of devices.
Discover our network monitoring, configuration management, network mapping, and free network tools today!
Enterprise-Class Network Management
Enterprise-Class Application & Server Management
Enterprise-Class Virtualization Management
Enterprise-Class Storage Management
Tools for Engineers
Easily monitoring bandwidth usage on a troublesome interface!
Record and test web transactions with the touch of a button!
Quickly discovers all of your virtual machines, then estimates what it would cost to move them to the cloud.
Prices displayed do not reflect international pricing unless otherwise stated. Please see our international price list for current pricing specific to your location.
All prices are subject to change without notice.
© 2003-2012 SolarWinds. All Rights Reserved.
