Welcome! Use the login menu to access:
Customer Portal
SolarWinds customers can download purchased software, renew maintenance, & more in our updated Customer Portal!
Community
After logging in, community members can rate & review SolarWinds software & participate in forums on thwack.com.
Partner Portal
SolarWinds channel partners will find all the resources they need in the Partner Portal, including exclusive partner tools.
| More
SolarWinds Knowledge Base
Export devices with unencrypted passwords using CatTools.
To export devices with unencrypted passwords using CatTools, perform the following steps:
  1. Open the following file within notepad: \CatTools3\KiwiCatTools-Settings.ini
  2. Within the [Properties] section, add the following line: Encryption=0
  3. Save the file.
  4. Close then reopen CatTools Manager.
  5. Export your devices to tab-delimited files. The passwords will be unencrypted.
Related Articles
No related articles were found.
No attachments were found.
Visitor Comments
No visitor comments posted. Post a comment
Post Comment for "Export devices with unencrypted passwords using CatTools."
If this article does not provide the solution you need, please consider visiting our community forums on thwack or contacting SolarWinds Support. Please use the following form to provide comments that help us improve this KB article. Fields marked with an asterisk are required.
   Name:
* Email:
* Comment:
* Enter the code below:
Article Details
Last Updated
6th of September, 2011
Would you like to...
Print this page  Print this page
Email this page  Email this page
Post a comment  Post a comment
 Subscribe me
Subscribe me  Add to favorites
Remove Highlighting Remove Highlighting
Edit this Article
Quick Edit
Export to PDF
User Opinions
No users have voted.
How would you rate this answer?
Thank you for rating this answer.
Continue
