Welcome! Use the login menu to access:
Customer Portal
SolarWinds customers can download purchased software, renew maintenance, & more in our updated Customer Portal!
Community
After logging in, community members can rate & review SolarWinds software & participate in forums on thwack.com.
Partner Portal
SolarWinds channel partners will find all the resources they need in the Partner Portal, including exclusive partner tools.
| More
SolarWinds Knowledge Base
What kind of SQL Server licensing does SolarWinds require?
Disclaimer: The following is our interpretation of Microsoft's licensing guidance. Be aware that licensing terms may change and differ between versions. If you have any doubt about your Microsoft® SQL Server® licensing terms, contact Microsoft.
You do not need to worry about Microsoft SQL Server licensing for the following SolarWinds products because they do not use Microsoft SQL Server:
  • Backup Profiler
  • Hyper9 Virtualization Manager
  • ipMonitor
  • Kiwi Syslog
  • LANsurveyor
  • Log & Event Manager
  • Storage Manager
  • Toolset, Engineer's or Standard
  • Virtualization Manager
SolarWinds Orion products require a licensed Microsoft SQL Server 2005, 2008, or 2008 R2 database*. Microsoft licenses SQL Server through Client Access Licensing (CAL) or by the processor. With respect to SolarWinds Orion products, you may choose from three licensing options:
  1. License by the processor instead of using CALs.
  2. License by user CAL and purchase one user CAL for every user who will access the Orion Web Console.
    Example: You have a five-person IT team who will be using Orion NPM. This scenario requires 5 user CALs.
  3. License by device CAL and purchase one device CAL for every Orion polling engine.
    Example: SolarWinds Orion NPM and NTA are installed on the same server and you also have one additional poller somewhere else. This scenario requires two device CALs.
Considering these three possible licensing options will help you find the most cost-effective SQL Server licensing method for your environment.
*Microsoft SQL Server 2012 is incompatible with SolarWinds Orion products. Do not purchase SQL Server 2012 licenses for use with SolarWinds products.
Related Articles
No related articles were found.
No attachments were found.
Visitor Comments
No visitor comments posted. Post a comment
Post Comment for "What kind of SQL Server licensing does SolarWinds require?"
If this article does not provide the solution you need, please consider visiting our community forums on thwack or contacting SolarWinds Support. Please use the following form to provide comments that help us improve this KB article. Fields marked with an asterisk are required.
   Name:
* Email:
* Comment:
* Enter the code below:
Article Details
Last Updated
19th of April, 2012
Would you like to...
Print this page  Print this page
Email this page  Email this page
Post a comment  Post a comment
 Subscribe me
Subscribe me  Add to favorites
Remove Highlighting Remove Highlighting
Edit this Article
Quick Edit
Export to PDF
User Opinions
100% thumbs up
(2 votes)
0% thumbs down
(0 votes)
How would you rate this answer?
Thank you for rating this answer.
Continue
