Configuring Cisco IOS Routers and Switches to Syslog to Your LEM Appliance
This document outlines the procedures for configuring Cisco IOS devices to log to the LEM appliance and configuring the Cisco PIX and IOS tool on the LEM Manager.
To configure your Cisco IOS routers and switches, complete the following procedure:
- Connect to your Cisco IOS device using an SSH or Telnet client.
- Login using administrative credentials for the device.
- Enter
enable.
- Reenter the administrative password for the device.
- Enter
configure and press Enter after the "How would you like to configure?" prompt.
- Enter
logging LEM_IP_address.
Note: LEM_IP_address is the IP address of your LEM Manager.
- Enter
logging facility local2. This defines where the LEM Manager will look for the IOS logs.
- Enter
logging trap debug.
- Enter
exit to return to the previous prompt.
- Enter
copy run start to ensure the device reboots with the new configuration.
- When asked about the destination, press Enter.
To configure the Cisco PIX and IOS tool on your LEM Manager, complete the following procedure:
- Navigate to the Manage > Appliances view in the LEM Console and log onto the LEM Manager on which you want to configure the tool.
- Click the gear icon next to the LEM Manager, and select Tools.
- In the Tool Configuration window, enter
Cisco in the search box at the top of the Refine Results pane.
- Click the gear icon next to the Cisco PIX and IOS tool, and select New.
- Replace the Alias value with a more descriptive tool alias. For example,
IOS Switch 1.
- Verify the Log File value matches the local facility defined in Step 7.
- If you are finished configuring the tool, click Save.
- Click the gear icon next to the new tool, and select Start. The Status icon will turn green to indicate the tool has started.
- Click Close to close the Tool Configuration window.
Once the tool is running, you can create a filter to display all traffic from that device. For example, your filter conditions might read, Any Alert.ToolAlias = *IOS Switch 1* using the example above, where the asterisks serve as wildcard characters.
Related Articles
No related articles were found.
No attachments were found.
Visitor Comments
No visitor comments posted.
Post a comment
Post Comment for "Configuring Cisco IOS Routers and Switches to Syslog to Your LEM Appliance"
If this article does not provide the solution you need, please consider visiting our community forums on thwack or contacting SolarWinds Support. Please use the following form to provide comments that help us improve this KB article. Fields marked with an asterisk are required.
