Welcome! Use the login menu to access:
Customer Portal
SolarWinds customers can download purchased software, renew maintenance, & more in our updated Customer Portal!
Community
After logging in, community members can rate & review SolarWinds software & participate in forums on thwack.com.
Partner Portal
SolarWinds channel partners will find all the resources they need in the Partner Portal, including exclusive partner tools.
| More
SolarWinds Knowledge Base
Export to PDF is not retaining filter information for event, alert, syslog, traps, or message center views
In some versions of Orion NPM, the conditions applied in a filtered event, alert, syslog, traps, or message center view may not be retained when the filtered view is exported to PDF. This is a known issue that will be addressed in a future release of Orion NPM.
The following procedure serves as a workaround, allowing you to retain all filter settings passed in the URL of the view you are exporting to PDF.
To retain filter settings when exporting an event, alert, syslog, traps, or message center view to PDF:
  1. Configure your filtered web console view. For more information about configuring event, alert, syslog, traps, or message center views, see the corresponding sections of your SolarWinds product Administrator Guide, available on the SolarWinds Product Documentation Page.
  2. Click Refresh, and then confirm that all filter options have been applied.
  3. Click Printable Version.
  4. Remove the string Printable from the generated URL, and then press Enter.
  5. Click Export to PDF.
This article applies to Orion NPM 10.1 and higher
Related Articles
No related articles were found.
No attachments were found.
Visitor Comments
No visitor comments posted. Post a comment
Post Comment for "Export to PDF is not retaining filter information for event, alert, syslog, traps, or message center views"
If this article does not provide the solution you need, please consider visiting our community forums on thwack or contacting SolarWinds Support. Please use the following form to provide comments that help us improve this KB article. Fields marked with an asterisk are required.
   Name:
* Email:
* Comment:
* Enter the code below:
Article Details
Last Updated
29th of June, 2011
Would you like to...
Print this page  Print this page
Email this page  Email this page
Post a comment  Post a comment
 Subscribe me
Subscribe me  Add to favorites
Remove Highlighting Remove Highlighting
Edit this Article
Quick Edit
Export to PDF
User Opinions
No users have voted.
How would you rate this answer?
Thank you for rating this answer.
Continue
