Welcome! Use the login menu to access:
Customer Portal
SolarWinds customers can download purchased software, renew maintenance, & more in our updated Customer Portal!
Community
After logging in, community members can rate & review SolarWinds software & participate in forums on thwack.com.
Partner Portal
SolarWinds channel partners will find all the resources they need in the Partner Portal, including exclusive partner tools.
| More
SolarWinds Knowledge Base
How to capture a memory dump
If a process appears to have a memory leak, you will need to capture a memory dump to confirm the leak. The following procedure provides the steps required to capture a memory dump.
To capture a memory dump:
  1. Determine the process ID (PID), as indicated in the following steps:
    1. Open Task Manager (press Ctrl+Alt+Del, and then click Start Task Manager.)
    2. Open the Processes tab.
    3. Click View > Select Columns.
    4. Check PID (Process Identifier), and then click OK.
  2. Record the PID assigned to the process that appears to be leaking memory.
  3. Download the correct Debug Tools archive for your server (32- or 64-bit):
  4. Extract the Debug Tools archive to an appropriate location on your Orion server.
  5. Open a command prompt and navigate to the location of your extracted archive.
    Note: the extracted archive should include TakeSnapShot.bat.
  6. Run TakeSnapShot.bat PID#, PID# is the PID of the apparently leaking process. For example, if you suspect that a process with a PID of 1234 is leaking, execute TakeSnapShot.bat 1234.
  7. Wait for the minimized window in your task bar to open and close
    Note:The window may have a title similar to cdb.exe or the full path of the extracted archive. It may take up to a few minutes for the operation to start, finish, and close on its own.
  8. There should be Output directory in the folder of the extracted archive. Create a .zip archive and send it to the SolarWinds Support representative who requested it.
    Note: Your new. compressed archive may be rather large.
This article applies to:
All supported SolarWinds products
Related Articles
No related articles were found.
No attachments were found.
Visitor Comments
No visitor comments posted. Post a comment
Post Comment for "How to capture a memory dump"
If this article does not provide the solution you need, please consider visiting our community forums on thwack or contacting SolarWinds Support. Please use the following form to provide comments that help us improve this KB article. Fields marked with an asterisk are required.
   Name:
* Email:
* Comment:
* Enter the code below:
Article Details
Last Updated
12th of November, 2010
Would you like to...
Print this page  Print this page
Email this page  Email this page
Post a comment  Post a comment
 Subscribe me
Subscribe me  Add to favorites
Remove Highlighting Remove Highlighting
Edit this Article
Quick Edit
Export to PDF
User Opinions
100% thumbs up
(1 vote)
0% thumbs down
(0 votes)
How would you rate this answer?
Thank you for rating this answer.
Continue
