SolarWinds Orion modules and standalone products are compatible with the specific versions of SolarWinds Orion Network Performance Monitor (NPM) shown in the following tables. Standalone products do not require any other SolarWinds products to be installed. To upgrade from earlier versions of Orion NPM or any of its modules, follow the given upgrade path.
Standalone products:
Orion NPM 7.8.5 ⇒ 8.5.1 ⇒ 9.1 ⇒ 10.0 ⇒ 10.2
| NPM 8.5.1 |
NPM 9.0 |
NPM 9.1 |
NPM 9.5 |
NPM 9.5.1 |
NPM 10 |
NPM 10.1 / Core 2010.2 |
NPM 10.1.1 / Core 2010.2.1 |
NPM 10.1.2 / Core 2011.1 |
NPM 10.1.3 / Core 2011.1.1 |
NPM 10.2.X / Core 2011.2.X |
| Orion AM | ✓ | ✓ | |||||||||
| Orion APM 1.0 | ✓ | ✓ | |||||||||
| Orion APM 2.0 | ✓ | ✓ | ✓ | ||||||||
| Orion APM 2.5 | ✓1 | ✓ | ✓ | ✓ | ✓ | ||||||
| Orion APM 3.0 | ✓ | ✓ | ✓ | ||||||||
| Orion APM 3.1 | ✓2 | ✓ | ✓ | ||||||||
| Orion APM 3.5 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||
| Orion APM 4.0 |
✓3 | ✓3 | ✓3 | ✓3 | ✓3 | |||||
| Orion APM 4.0.1 |
| Orion APM 4.0.2 |
✓3 | ✓3 | ✓3 | |||||||
| Orion APM 4.2 |
✓3 | ✓3 | ||||||||
| SW SAM 5.0 |
✓3 |
1Not recommended
2Orion NPM 9.5 Service Pack 4
3Orion APM 4.0 and higher are standalone products that do not require Orion NPM, but they may be installed with Orion NPM. Orion APM 4.0 may be installed with Orion NPM 10.1 or higher. Orion APM 4.0.2 requires Orion NPM 10.1.2 or higher. Orion APM 4.2 requires Orion NPM 10.1.3 or higher. SW SAM requires NPM 10.2.2 or higher.
Orion NPM 8.5.1 ⇒ Orion APM 2.0 ⇒ Orion NPM 9.1 ⇒ Orion APM 2.5 ⇒ Orion NPM 10.0 ⇒ Orion APM 3.5 ⇒ Orion NPM 10.2 ⇒ Orion APM 4.2
Note: Standalone Orion APM upgrades Orion APM 4.0 ⇒ Orion APM 4.0.2
| NPM 8.5.1 |
NPM 9.0 |
NPM 9.1 |
NPM 9.5 |
NPM 9.5.1 |
NPM 10 |
| Orion EOC 1.2.0 | ✓1 | ||||||||||
| Orion EOC 1.2.0 SP1 | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||
| Orion EOC 1.2.0 SP2 | ✓ | ||||||||||
| Orion EOC 1.3.0 | ✓ | ✓ | ✓ | ||||||||
| Orion EOC 1.3.0 SP1 | ✓ |
1Orion EOC 1.2.0 SP1 is recommended
| NPM 8.5.1 |
NPM 9.0 |
NPM 9.1 |
NPM 9.5 |
NPM 9.5.1 |
NPM 10 |
| Orion FOE 6.4.0 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ||||
| Orion FOE 6.4.1 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
| NPM 8.5.1 |
NPM 9.0 |
NPM 9.1 |
NPM 9.5 |
NPM 9.5.1 |
NPM 10 |
| Orion IPAM 1.0 | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||
| Orion IPAM 1.0.1 | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||
| Orion IPAM 1.5 | ✓1 | ✓ | ✓ | ||||||||
| Orion IPAM 1.6 | ✓1 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ||||
| Orion IPAM 1.7 | ✓1 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ||||
| Orion IPAM 1.7.1 | ✓1 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||
| Orion IPAM 2.0 | ✓ | ✓ | ✓ | ||||||||
| Orion IPAM 2.0.1 | ✓ | ✓ | ✓ | ||||||||
| Orion IPAM 3.0 | ✓ | ✓ | ✓ |
1Orion NPM 9.5 Service Pack 5
Orion IPAM 1.0 ⇒ Orion NPM 9.1 ⇒ 10.0 ⇒ IPAM 1.5 ⇒ 1.7 ⇒ Orion NPM 10.2
| NPM 8.5.1 |
NPM 9.0 |
NPM 9.1 |
NPM 9.5 |
NPM 9.5.1 |
NPM 10 |
| Orion VoIP 1.0 | ✓ | ||||||||||
| Orion VoIP 2.0.x | ✓ | ✓ | |||||||||
| Orion VoIP 2.1 | ✓ | ✓ | ✓ | ✓ | ✓ | ||||||
| Orion IPSLAM 3.0 | ✓1 | ✓ | ✓ | ||||||||
| Orion IPSLAM 3.1 | ✓1 | ✓ | ✓ | ||||||||
| Orion IPSLAM 3.5 | ✓1 | ✓ | ✓ | ||||||||
| Orion IPSLAM 3.5.1 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ |
1Not recommended
Orion VoIP 2.0 ⇒ Orion NPM 8.5.1 ⇒ 9.0 ⇒ Orion VoIP 2.1 ⇒ Orion NPM 9.1 ⇒ 10.0 ⇒ Orion IPSLAM 3.5.1 ⇒ Orion NPM 10.2
| NPM 8.5.1 |
NPM 9.0 |
NPM 9.1 |
NPM 9.5 |
NPM 9.5.1 |
NPM 10 |
| Orion NTA 2.2 | ✓ | ||||||||||
| Orion NTA 2.2.1 | ✓ | ✓ | |||||||||
| Orion NTA 3.0 | ✓ | ✓ | ✓ | ||||||||
| Orion NTA 3.1 | ✓1 | ✓ | ✓ | ✓ | |||||||
| Orion NTA 3.5 | ✓ | ✓ | ✓ | ||||||||
| Orion NTA 3.6 | ✓2 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ||||
| Orion NTA 3.7 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ||||
| Orion NTA 3.8 | ✓ | ✓ | ✓ | ✓ | ✓ |
1Not recommended
Orion NPM 8.5.1 ⇒ Orion NTA 3.0 ⇒ Orion NPM 9.1 ⇒ Orion NTA 3.1 ⇒ Orion NPM 9.5.1 ⇒ Orion NTA 3.7 ⇒ Orion NPM 10.2 ⇒ Orion NTA 3.8
| NPM 8.5.1 |
NPM 9.0 |
NPM 9.1 |
NPM 9.5 |
NPM 9.5.1 |
NPM 10 |
NPM 10.2.2/ Core 2011.2.2 |
| Orion NCM 5.0 | ✓ | ✓ | ||||||||||
| Orion NCM 5.1.x | ✓1 | ✓ | ✓ | ✓ | ||||||||
| Orion NCM 5.5 | ✓ | ✓ | ✓ | |||||||||
| Orion NCM 5.5.1 | ✓ | ✓ | ✓ | |||||||||
| Orion NCM 5.5.2 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||
| Orion NCM 6.0 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||
| Orion NCM 6.1 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||||
| Orion NCM 7.0 | ✓ | ✓ | ✓ | ✓ | ||||||||
| Orion NCM 7.0.1 | ✓ | ✓ | ✓ | ✓ | ||||||||
| Orion NCM 7.0.2 | ✓ |
1Not recommended
Orion Cirrus 4 ⇒ Orion NCM 5 ⇒ Orion NPM 9.1 ⇒ Orion NCM 5.1 ⇒ Orion NPM 9.5.1 ⇒ Orion NCM 5.5.2 ⇒ Orion NPM 10.1.3 ⇒ Orion NCM 6.0 ⇒ Orion NPM 10.2 ⇒ Orion NCM 6.1
| NPM 8.5.1 |
NPM 9.0 |
NPM 9.1 |
NPM 9.5 |
NPM 9.5.1 |
NPM 10 |
| SolarWinds SEUM 1.0 | ✓1 | ✓1 | ✓1 | ||||||||
| SolarWinds SEUM 1.5 | ✓1 | ✓1 | ✓1 |
1 SolarWinds SEUM does not require Orion NPM but can integrate with it.
| NPM 8.5.1 |
NPM 9.0 |
NPM 9.1 |
NPM 9.5 |
NPM 9.5.1 |
NPM 10 |
| Toolset 10.5.0 | ✓ | ✓ | ✓ | ✓ | |||||||
| Toolset 10.6.0 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ||||
| Toolset 10.7.0 | ✓ |
| NPM 8.5.1 |
NPM 9.0 |
NPM 9.1 |
NPM 9.5 |
NPM 9.5.1 |
NPM 10 |
| SolarWinds UDT 1.0 | ✓1 | ✓1 | ✓1 | ||||||||
| SolarWinds UDT 1.0.1 | ✓1 | ✓1 | ✓1 | ||||||||
| SolarWinds UDT 2.0 | ✓1 |
1 SolarWinds UDT does not require Orion NPM but can integrate with it.
Last Updated
14th of May, 2012
