Welcome! Use the login menu to access:
Customer Portal
SolarWinds customers can download purchased software, renew maintenance, & more in our updated Customer Portal!
Community
After logging in, community members can rate & review SolarWinds software & participate in forums on thwack.com.
Partner Portal
SolarWinds channel partners will find all the resources they need in the Partner Portal, including exclusive partner tools.
| More
SolarWinds Knowledge Base
What is ConnectNow?
Using the ConnectNow tool, Network Atlas can automatically draw lines between map objects that are directly connected on your network, as shown in the following procedure.
Notes:
  • The ConnectNow tool cannot create indirect connections. For example, if the map objects A and C are connected indirectly through device B, you must manually add device B to the map to create the connections.
  • Because topological data about your network is only generated during Network Sonar Discovery, ConnectNow can only draw lines between discovered nodes. Nodes that are added manually, as in Web Node Management, cannot be connected using ConnectNow.
To automatically connect objects using ConnectNow:
  1. Add appropriate objects to an open network map.
    Note: For more information about adding objects to a network map, see "Adding Map Objects" in the SolarWinds Orion Network Atlas Administrator Guide.
  2. Click Home > ConnectNow.
This article applies to:
Orion Network Atlas versions 1.2 and higher
Orion Network Performance Monitor 10.0 and higher
Related Articles
No related articles were found.
No attachments were found.
Visitor Comments
No visitor comments posted. Post a comment
Post Comment for "What is ConnectNow?"
If this article does not provide the solution you need, please consider visiting our community forums on thwack or contacting SolarWinds Support. Please use the following form to provide comments that help us improve this KB article. Fields marked with an asterisk are required.
   Name:
* Email:
* Comment:
* Enter the code below:
Article Details
Last Updated
6th of August, 2010
Would you like to...
Print this page  Print this page
Email this page  Email this page
Post a comment  Post a comment
 Subscribe me
Subscribe me  Add to favorites
Remove Highlighting Remove Highlighting
Edit this Article
Quick Edit
Export to PDF
User Opinions
40% thumbs up
(2 votes)
60% thumbs down
(3 votes)
How would you rate this answer?
Thank you for rating this answer.
Continue
