Your changes will require approval by an administrator before they are published.
The article has been updated successfully but requires approval before it is published.Explanation
If NCM 6.0 is integrated into Orion 10.0, the software makes available a Topology Report called 'Discovered Links'. This report shows the devices to which your switches and routers are connected, as recorded in the database by the Network Discovery Engine during its latest iteration of discovery.
Prerequisites for viewing 'Discovered Links' data for Orion nodes are:
If you import nodes into Orion from another source, such as another SQL Server database, you must run the Network Discovery engine on that set of nodes in order to capture current switch port mapping information.
Essentially, since every network object monitored in Orion requires a license, you must have licenses to cover all the interfaces for which you want to see topology reports, and those interfaces must be specifically set up to be monitored in Orion.
Version
The 'Discovered Links' report is available only in the Orion Web Console if you have NCM 6.0 installed, and its integration moduled installed, on your Orion server.
Last Updated
6th of August, 2010
Thank you for rating this answer.
SolarWinds makes award-winning storage management, application management, server management, and network management software trusted by more than one million engineers to manage IT environments ranging from tens to thousands of devices.
Discover our network monitoring, configuration management, network mapping, and free network tools today!
Enterprise-Class Network Management
Enterprise-Class Application & Server Management
Enterprise-Class Virtualization Management
Enterprise-Class Storage Management
Tools for Engineers
Easily monitoring bandwidth usage on a troublesome interface!
Record and test web transactions with the touch of a button!
Quickly discovers all of your virtual machines, then estimates what it would cost to move them to the cloud.
Prices displayed do not reflect international pricing unless otherwise stated. Please see our international price list for current pricing specific to your location.
All prices are subject to change without notice.
© 2003-2012 SolarWinds. All Rights Reserved.
