Welcome! Use the login menu to access:
Customer Portal
SolarWinds customers can download purchased software, renew maintenance, & more in our updated Customer Portal!
Community
After logging in, community members can rate & review SolarWinds software & participate in forums on thwack.com.
Partner Portal
SolarWinds channel partners will find all the resources they need in the Partner Portal, including exclusive partner tools.
| More
SolarWinds Knowledge Base
Interface tooltips showing utilization at higher than 100%, even when the Top XX Interface Utilization resource shows utilization at a maximum of 100%
Orion NPM is reporting the interface bandwidth as provided by the interface itself. To correct the polled interface bandwidth, edit the interface, as shown in the following procedure.
To edit an interface bandwidth:
  1. Click the interface name to open the corresponding Interface Details view.
  2. In the Interface Details resource, click Edit Interface in the Management section.
  3. Check Custom Bandwidth in the Bandwidth section.
  4. Provide correct values for Transmit Bandwidth and Receive Bandwidth.
  5. Click Submit.
This article applies to:
Orion Network Performance Monitor version 9.5 and higher
Related Articles
No related articles were found.
No attachments were found.
Visitor Comments
No visitor comments posted. Post a comment
Post Comment for "Interface tooltips showing utilization at higher than 100%, even when the Top XX Interface Utilization resource shows utilization at a maximum of 100%"
If this article does not provide the solution you need, please consider visiting our community forums on thwack or contacting SolarWinds Support. Please use the following form to provide comments that help us improve this KB article. Fields marked with an asterisk are required.
   Name:
* Email:
* Comment:
* Enter the code below:
Article Details
Last Updated
16th of June, 2010
Would you like to...
Print this page  Print this page
Email this page  Email this page
Post a comment  Post a comment
 Subscribe me
Subscribe me  Add to favorites
Remove Highlighting Remove Highlighting
Edit this Article
Quick Edit
Export to PDF
User Opinions
No users have voted.
How would you rate this answer?
Thank you for rating this answer.
Continue
