Welcome! Use the login menu to access:
Customer Portal
SolarWinds customers can download purchased software, renew maintenance, & more in our updated Customer Portal!
Community
After logging in, community members can rate & review SolarWinds software & participate in forums on thwack.com.
Partner Portal
SolarWinds channel partners will find all the resources they need in the Partner Portal, including exclusive partner tools.
| More
SolarWinds Knowledge Base
Kiwi Syslog Daemon is not receiving messages
Sometimes, even though you have installed Kiwi Syslog Daemon and you have configured your network devices, you may find that Kiwi Syslog Daemon is not receiving, or displaying any information.
This guide is designed to take you through the most common causes for this, and hopefully provide a solution.
The links below will guide you through these common issues.
Steps to trouble shooting Kiwi Syslog Daemon
Step 1.    Confirm that your network devices are configured
Step 2.    Confirm that messages are actually arriving
Step 3.    Load the Kiwi Syslog Daemon default settings
Step 4.    Check the Kiwi Syslog Daemon Error log
Step 5.    Unable to bind to UDP port 514 (or similar)
Step 6.    Check the Windows Firewall
Step 7.    Send a test message
Step 8.    Use Kiwi SyslogGen to send a test message
Related Articles
No attachments were found.
Visitor Comments
No visitor comments posted. Post a comment
Post Comment for "Kiwi Syslog Daemon is not receiving messages"
If this article does not provide the solution you need, please consider visiting our community forums on thwack or contacting SolarWinds Support. Please use the following form to provide comments that help us improve this KB article. Fields marked with an asterisk are required.
   Name:
* Email:
* Comment:
* Enter the code below:
Article Details
Last Updated
27th of August, 2010
Would you like to...
Print this page  Print this page
Email this page  Email this page
Post a comment  Post a comment
 Subscribe me
Subscribe me  Add to favorites
Remove Highlighting Remove Highlighting
Edit this Article
Quick Edit
Export to PDF
User Opinions
100% thumbs up
(1 vote)
0% thumbs down
(0 votes)
How would you rate this answer?
Thank you for rating this answer.
Continue
